Is my H2D punishing me?
My setup : H2D , AMS 2 Pro on Left nozzle, AMS on Right nozzle.
Sliced a 4 colour print and with current spool locations I was given 29 hours, H2D said if I swapped 2 spools it will be 2 hours less.
I swapped the 2 spools and sliced and it said 30 hours , what ???
Annoyed I just put back my spools to original slots expecting the same 29 hours, it came back with 31 hours :roll_eyes:
Since there was no slicer software change, I am guessing something to do with AI ?
You do not need to slice it again to print, just swap the spools, hit PRINT and let your printer do the magic.
Thanks but I like the display to show correct spool position :slight_smile:
Also the extra 2 hours for exactly the same thing ?
Print it and see! For a print that long I’d personally not really care about an hour or two of a difference since it’s already going to take ages. Good luck!
I only encountered this issue once while using two AMS 2 Pros. The slicer displayed the correct filaments, but for some reason, the right AMS filament slot kept defaulting to a generic filament, and I wasn’t able to change it through the printer screen. I went ahead and clicked ‘Print’ just to see what would happen, and it started printing anyway… :roll_eyes:
After rebooting both the printer and Bambu Studio, everything started working properly.
I’m not sure if this happened to you too, but the generic version has a different max flow rate and this would change the print times.
I’m not sure whether it’s an AMS bug or just a one-time can-bus communication issue.
But I’m keeping my fingers crossed.
Thank you all for the insight and advice :slight_smile:
I did just encounter another small annoyance.
I used convenience mode for a 3 colour print, one on left, 2 on right. The H2D kept insisting one of the reels was on the other side(all was synced so it was wrong).
I manually moved the offending reel grouping on screen to the other side.
If there were no slicer or setting changes, why would just swapping spool positions cause a different time estimate? Is the slicer re-optimizing toolpaths based on AMS slot order or nozzle assignment?
Nozzle assignment changes, so it factors in color changes
My guess… it was out of sync initially and calculated the best way to complete the print with old information, then when it was updated and re-sync’ed, it gave a new and fully updated assessment.
