I have noticed today that I got empty lines on cubic infill, I don’t remind that it was the case before ?
Nobody has this problem?
I use that infill type & have not seen layer gaps like that before. Seems like several people are experiencing issues with latest firmware.
Ok, thanks, I will post an issue
I recently enabled the infill combination (combine infill) option and have found it fixes the grid pattern overextrusion (I think thats what is going on with Grid) and also Gyroid infill goes down nicer
If you’re using Cubic try checking that option off (I mean on, you know what I mean lol) and see if it improves the Gcode generation
So far I’m leaving it saved in the selected position by default in my settings
We got exactly the same Issue. Cubic/Adaptive Cubic was working well before, now it’s unusable. There are empty lines exactly as shown above.
Apparently this is just a bug on the preview, it print fine :
