Is there a way to change which Wi-Fi the p1p is set to?
Hi all.
I was forced to set my p1p to my mobile hotspot due to the printer being unable to bind to my regular wifi. (Nothing wrong with the wifi, and its fully compatible)
Is there any way to change the wifi settings on the printer as I don’t want to constantly keep it tethered to my phone?
Additionally. I cannot seem to get a stable connection via my phone to the cloud service, so I am unable to send across print files.
If you need any more information, don’t hesitate to ask - I know I have been pretty vauge in order to stay concise.
This may be unrelated, but it could impact how the printer does its function. the unbranded micro SD card that came inside the printer is completely corrupt. I am unable to get a solid read/write out of it without it throwing up loads of errors. Ill see if the problem persists once I clone the contents onto a branded microSD
Replacing the micro SD made everything work first time after that change
Hi,
on LCD Display select Options, highlight WLAN, press OK.
Now it shows your WLAN and IP, hit OK again.
Now it shows your WLAN und under it ‘Forget it’. If you press OK, it should reset the WLAN.
I have not tried it, only found the option.
That “forget it” option DOES clear your wlan setting. Just tried it!
This worked great for me, and I went into the app on my phone and selected a different WiFi network. Thanks.
Here is the solution I encountered for this problem, just google for the p1-sd-card-network-configuration-guide and there is a detailed step by step on how to fix it.
