Is there a way to Pause at layer X to manually change filament?
So, I have a project that would be perfect with a 5th color. Is there a way, other than running out of filament, to program a pause at a certain layer height or certain spot within the print to re-load a filament in? You can obvious hit the manual pause button, but that requires precise timing and monitoring
slice, then in preview you can drag the layer slider to the height you want. Right click the slider, add pause.
In addition to what @Hobo4ssassin describes, I think there’s a few somewhat related topics that may point you in the right direction.
There’s some good pointers here:
like here
awesome, thanks all! The right click seems so simple now XD all that really helps
This option does not show up without an AMS installed. There is still no way to do change filament other than inserting a Pause and dealing with that less than optimal route to swap filament.
New customer/user here with A1 Mini, no AMS connected.
It was quite the letdown in user experience.
Bambu Studio showed each color filament change, happily starts printing, but not actually paused to let me change colors. Misleading or incomplete at best.
And the UI needs more improvement, it somehow listed showed 9 colors while the model only used 4.
Model was “X Wing in hyperspace by CrazyFilament - MakerWorld” (no links allowed on this forum.
Yeah, I have a problem with this. I often want to put some text on a model and have to choose Pause to get the print to stop while I change colour. This worked fine a few months ago but now when I try it, it won’t let me change filament. The filament Load/Unload command won’t function. Sometimes the Change Filament option is available (and sometimes not) but when I use it the slicer gives me a whole lot of AMS grief that I don’t understand. What is mapping and overwriting and syncing?? Is there a clear how-to document that is dedicated to us non AMS people? I dont’t have one and I don’t want one.
