I have a model that has fine detail only on the top surface that requires the .2mm nozzle. The rest of the object has no detail and could be printed with the .6mm nozzle.
If I use the 2mm, the job takes 10 hours. I know i could reduce that drastically if I could print the lower part with the large nozzle, and just the top layer with .2mm. Is there a way to do that?
Update: Interestingly, I just discovered that if I split the object into 2 separate bodies, the top slice and the base, still using the 0.2mm nozzle throughout, I reduce the print time to under 2 hours. I’m not sure why there is so much savings there. Still, I wonder if my original question is possible.
