Is your rapid to center past the cutter cams this loud?
Attached is a link to a quick video of the rapid near the start of a print. Its very loud to me when it goes past the cutter cams at full speed. Any thoughts?
You might want to push the head manually to the rear (printer off) and check if you feel a lot of resistance.
Is this since the beginning already that loud?
It is fairly noisy on my printer also, but from a recording it’s hard to judge how loud yours is.
Everything sounds normal to me it’s just like mines is.
the toolhead moves freely by hand all directions. Its that first rapid at the start of the print to center that is so loud. It bangs past the cutter cams. But all the other rapid moves past the cutter cams isnt as loud.
Maybe that first one is the max travel speed??
I dont see why that has to be so fast at that point. Even a rapid at half speed will only chew up a half a second.
