I replaced the original hotend to a hardened nozzle. I also changed the setting to a hardened nozzle in the printer.
The nozzle was hard to remove because there was some plastic that came out and got behind and attached it to the housing. I had to head it up to remove it and wipe the inside down.
Once I replaced it and tried to print it keeps staying “The hotend cooling fan speed is abnormal”
I tried it. I can freely spin the fan and I even though I did not remove or touch the fan wires previously, I did reseat them with no luck.
Is it possible I damaged the thermal wire by the hardened hotend? I heard it wont heat but maybe it wont turn the fan on? I see this being the issue but trying to think of anything at this point.
