Issue with applying text to model
I have a simple print-in-place case and want to add text to the face that is facing the build plate. I’ve done this several times before without any issues, but I’m running into a problem with this model.
I’m using a modifier for the text and assigning black filament to the text. The settings are:
● Minimum thickness: 0.10 mm
● Depth: 0 mm
Everything looks correct in the Pre-Slice view. The two colors are visible, and the AMS shows that both filaments will be used (green case / black text).
However, as soon as I slice the model, the black text completely disappears. I also tested using Text Cut without assigning a color, and the text still disappears after slicing.
The text is essentially intended to be on the first layer, since that face is against the build plate.
I’m not sure if this is a setting/geometry issue or a bug in Bambu Studio. Has anyone run into this before, or know what could be causing the text to disappear after slicing?
