I’m still new to 3D printing, so this maybe a newbie question.
I recently bought my second spool of black PETG and it is like a rock. The filament strands are stuck together. It feed off about one turns worth of filament and then broke.
I have it now stored in a airtight conatainer and the humidity is down to 15%. Am I doing something wrong? or is there a simple fix I am missing?
I have had no issues with my other PETG or PLA spools.
Thanks
Is it fused together or just wound a bit too tightly? If its partly fused it could have gotten too hot (+70C) during transport and you should contact the seller to get a replacement/refund.
Thanks. It has fused together.
The spool came from Bambu so I have raised a support ticket for replacement/credit note.
I started using anycubic petg for around 12 bucks per kg petg when you get 2 and even cheaper when bulk buying, bbl petg at a much higher price point is worthless and prints worse for sure. I suggest if you don’t need specific colored petg from bbl to just get credit from them to buy replacement/spare parts and get another brand of petg
if you are using the stock petg profile from bambu, you need to change a lot of stuff to get good quality prints. Their petg profile isn’t as well tuned as their pla.
Some needed changes for example include but not limited to:
first layer and top surfaces 40mm/s
all other speeds to 80mm/s
enable retraction in filament settings, type spiral
Based on what you described, there is no acceptable way filament strands on a spool should ever be fused together. I did this once by overcooking a PETG spool using my oven during a drying experiment. It was a good lesson in what not to do. ![]()
The answer is simple and doesn’t require much analysis. If the product arrived in that fashion then the product is defective. Return it for a refund or new spool.
