filament dried for 12hrs straight out of packaging
done calibrations
.6 nozzle, hardened gears and nozzle
door closed
lid on
0 fans
bed temp 100c
nozzle 260c
10mm/s volumetric speed
.94 flow ratio (read somewhere this was the magic number)
Tried .95 and .96 flow and 12mm/s volumetric to no avail. Had no luck with the generic ASA profile in Bambu Slicer (doesn’t seem to be a profile for ASA-CF)
I’ve just had nothing but nightmares with PETG-CF. Was told ASA is a walk in the park in comparison.
Hi mate, I just did the Flow Dynamics and Flow Rate in Bambu Studio, and from memory, the standard values seemed to produce the most consistent results in the calibration.
Which filament brand?
Have you looked how it slices? Overhang is OK, but even with ASA-CF you can’t print in mid-air Reduce layer height to reduce %-age of filament that is hanging over.
Hi mate I will try this now. Overhang isn’t very steep at all. I have printed this same object with PETG and PLA many times without any overhang issue.
