Issues with bed adhesion, too hard adhesion
Hi everyone.
I had hard time with my bed adhesion on the bambulab, i used the one gived by the fabric directly, the cold plate for PLA, and also just printed with bambulab PLA.
From the very first print i used glue stick and put new cape before each print, but form the first one i had really hard time to separate the print part from the bed.
I printed the scraper, so it work just a little bot better, and finished destroying the bed sheet with the razor.
Did someone had that much trouble? did i skip to do something? can you give me an advice for the next bed sheet to have less work separating the part from the bed?
thanks everyone!
get the texture pei sheet. no glue needed and releases nice. Love mine
I have not had that problem. With glue they can stick but I use a putty knife not that razor supplied. That razor is to dangerous!
I also have the Double Sided PEI.
If you are still having issues try letting the plate cool down completely, then bend the plate to help release, then a putty knife.
you true about the razor, i saw a redisned one that seemed to help not go too deeper.
even so when you counter balance with a knife or a scraper it feels also that i destroy the sheet.
that’s why i hope to find to make the separation smoother
