Issues with ftp connection
Hi.
I am trying to connect to my X1C via FTP using the “FTPRush” client on my mac. I am using the access code and can login with no issues, but I get the error message below (SSL connection failed: session reuse required) and cannot mount the SD card. Anyone has any idea how to fix this? Thank you!
[1][FTP]Status: Start Login FTP(bblp@10.0.1.28:990) …
[1][FTP]Status: Connecting to 10.0.1.28:990
[1][FTP]Status: SSL Certificate Issuer: CN=BBL CA, O=BBL Technologies Co., Ltd, C=CN
[1][FTP]Status: SSL Encryption: TLS 1.2
[1][FTP]Status: FTPS Authentication Successful
[1][FTP]Status: Detected FTP server: VsFTPd
[1][FTP]Status: Text encoding: System.Text.UTF8Encoding
[1][FTP]Status: Login FTP(bblp@10.0.1.28:990) Successfully
[1][FTP]Status: Start List directory / …
[1][FTP]Status: Connecting to 10.0.1.28:50013
[1][FTP]Error: SSL connection failed: session reuse required
Sorry I not using Mac and I don’t know if this will help you out.
But did you have a area you can select this ?
TLS/SSL Implicit encryption
Yes, implicit TSP is selected
You can try this one and see if you have any luck I use WinSCP and it works with the X1 but it is only windows.
FileZilla
I had to turn this on also but I don’t know if you have this option.
FTp
Thanks.
Unfortunately, I cannot find any such option in the software I am using.
Has anyone had luck connecting to mac OS? If yes, how are they connecting?
I just tried FileZilla and I can connect with no issue. Thanks all
I just connected via Transit 5 via the following settings:
Screenshot 2023-06-03 at 6.09.02 PM
Just change your IP address and password as appropriate to your printer (password is your printers Local Lan access code)
I was able to successfully connect using FileZilla version 3.64.0 on Windows 11 to my X1C here are the settings I used for me port number wasn’t required, hope this helps someone else out
I’m using FileZilla Pro - v … and I receive the error below, I’ve attached my connection settings as well. Anyone else having this issue?
|Status:      |Connecting to 10.158.X.X:990...|
|Status:      |Connection established, initializing TLS...|
|Status:      |TLS connection established, waiting for welcome message...|
|Response: |220 (vsFTPd 3.0.3)|
|Command: |USER bblp|
|Response: |331 Please specify the password.|
|Command: |PASS ********|
|Error:         |GnuTLS error -15 in gnutls_record_recv: An unexpected TLS packet was received.|
|Error:         |Could not read from socket: ECONNABORTED - Connection aborted|
|Error:         |Could not connect to server|
|Status:      |Waiting to retry...|
UPDATE: I turn on LAN only mode, recorded the access code (ftp password) and then turned it off again. Then I was able to successfully connect to my printer !!
HAZAH!
