Since the new firmware update I can not send files to sd card from slicer. What’s the issue here? So frustrating when you have everything working fine and then a firmware update messes everything up. I have tried logging out of both, switching wifi and rebooting. When trying to send the files to sd card it says. Failed uploading print file. Please enter ip address again. I do not and never have entered my ip address anywhere.
Same here as well… Just tried to upload a file to SD during Printing but is not working, get the message: Failed uploading print file.
Same problem for 3 days now, so annoying.
I’ve opened the issue please comment and watch it here:
Ive found that switching to a differant wifi on the slicer side seems to work. If you do not have muliple networks maybe try disconnecting from wifi then turn it back on.
Thx but in my case I’m wired on the desktop end and it was working prior the update.
Yep same problem here!
EDIT: Just reinstalled bambu lab . Now it works again!!
EDIT 2: After 1 day, I have the same issue again!!
This bug exists until january 2024!!!
I also have a similar issue but instead i cant “print plate” but can send prints
