It keeps saying "feed filament into the PTFE tube ... further
Even though I feel filament into it until it cannot be pushed any further, it keeps saying that error.
I did set up ABS filament on external spool and it keeps saying this.
No matter what kind of filament, it keeps saying it.
Is there any technique to avoid this?
Are both nozzles saying this?
Can you show photo of lcd the filament lines.
If you try to pull back the filament and it doesn’t move, that means the extruder gear has already gripped it.
Just push the lcd button
(filament extruded; continue)
Connect External Filament Spool
Thank you very much.
It kept saying that error while ABS filament was set in external spool and set into right nozzle.
Once I set that ABS filament on AMS PRO2, ABS filament worked fine and now it’s printing.
So weird.
Is it supposed to be possible to print with ABS that is set on external spool??
Ya you can print using external I have used it a few times already.
