Just finished upgrading my P1P to the P1S (So Cool !)
Best upgrade I’ve ever done to a printer, I do have a couple questions.
1 If your trying to create a semi sealed environment for VOC’s and higher temps why does the door not have a seal in the hinge side? There is clearly a gap that will be letting temp out as well as heat,
2 What is the G Code for the MC board to activate and shut down. and If I simply use the P1S as default do those settings work as they should.
3 I had to roll back from version 7.0 on the firmware because I printed the same exact file with the exact settings and had excessive stringing. Anyone else had this issue?
4 Bambu Studio 2.0 seems to be very buggy, and a very weird work flow. I really have no need for it’s other “Features” since I can never really afford an HD2. Is there really a need since I’m sticking with my 2 A1’s and my P1S now.
Thanks
M1
Well done.
  1. It is not meant to be vacuum sealed.
  2. If you mean to shut the printer down, meaning toggle the power switch, I am not sure that is possible due to the physical nature of the power switch.
  3. I have not performed the upgrade, but stringing is a thing in its own right.
    • Assuming you mean post-upgrade, does this occur with materials you couldn’t use before?
    • Does it occur with materials you used before the upgrade?
    If so, moisture is your likely issue. Photos of the failed prints help people diagnose things for you.
  4. I have not upgraded to version 2 due to the security stuff. Download an earlier version, everything works for now at least. It will give them time to fix the issues.
