K value calibration not selected - reset to zero at startup
After installing the latest updates (firmware and software), I immediately tested the calibration. As soon as it was done, the K values correctly appeared in the AMS graph, but occasionally, upon reboot, they are reset to zero and it’s necessary to reselect them. I use Bamboo Studio on different PCs, and the version is consistent across all of them. The issue occurs with both the latest version and the previous one.
1.7.3.50
1.7.2.51
It would be usefult to automatically load the latest K version used
K values at startup
Immagine 2023-08-09 110725
Selection in progress
Immagine 2023-08-09 110816
After having selected the right profile (petg in this case), the other values are still “unselected”.
Immagine 2023-08-09 110833
Immagine 2023-08-09 114244
Try without the Update on Startup checkbox. At least I didn’t check that option, as if I understood correctly, the AMS will record the last session filaments and reload it on startup. I do not have issues with reboots.
However, randomly I noticed that the filament info was not correctly synced between computers. I assumed that the settings are not being continuously synced globally. But this is just a hypothesis.
You’re probably right, I’ll try to disable the Update on Startup.
I think sync is not working continuously too…
Thanks!
Yes in last version have it
Look like data not load on startup program
if open manage result can show ?
try many time not work
You can manage results, but in the UI they’re still not loaded on startup.
I can’t understand if values are still considered when printing is launched even if they’re not displayed in the ui
