I’ve seen this happen once because there was a tangle in the spool and the printer was trying to correct itself…at least I think thats what was going on. I thought it was possessed it was so weird. Single color print I had done many times before. And yes there was a good tangle on the spool.
Been printing all week with TPU with no problems, on Tuesday I changed the tubing to all reels and continued to print.
Thursday I needed to print in PLA, that’s when the problem started, I did not even think about the tubing, but then it clicked, so I have refitted the old tubing and it’s working as normal.
I would say that this PTFE tubing even with a 2.5mm hole had a lot of friction causing the A1 to think the filament was stuck, as mentioned in the comments above.
This is the tubing I purchased from Amazon that even says it’s suitable for the A1 except for soft material, which worked fine.
