I print this one and filled complete plate
That part isn’t prone to warping because it doesn’t have enough height. Try printing a model (or test models) similar to what OP was printing. You will see that it is impossible to get fully straight bottom side once you reach few cm of height.
I know this is so long ago, but you can print the supports in the same material while only changing the interface layers to the multi-material to save time.
@Wyllio, I don’t know if there is an easy way to change just the interface layer. I think that would be very custom and I’m not sure it would benefit you. The best option for easier support removal here might be to and .02 to your interface layer heights (top and bottom).
