I’m printing a fairly large (230x180x68mm) flat model in petg hf on my P1S. With quality settings, it took 11h last night. I’m getting a little warping at the corners (see photo). It’s not horrible, but I’d like to improve it. Here’s some relevant info:
Unfortunately, there is no magical formula here. Three remedies quickly come to mind, listed in order from best suited to your needs to least suited.
Use brims. They will hold down the edges better.
Use Glue(I realize this defeats the cryogrip benefits)
Increase the plate temp(ill-advised for the cryogrip plate)
Give up and use a different plate altogether but even with a smooth engineering plate, lifting will occur with a model that sized. You simply cannot ignore the shrinkage.
Try slowing down the first layers using either the first speed function or you could use a layer modifier and try that.
Right-click on the model and select height range modifier.
In troubleshooting, I know that one must not “shotgun” the problem, rather try changing one variable at a time so you know what actually fixes it.
Yep, I think that I’ll try brims next (it had crossed my mind). I hate waiting 11h (and 380g) to find out, but I know if I take a slice of the model, say only 20mm high (approx 3.2h), that doesn’t prove anything as the cooling dynamics of a 68mm high model over a much longer time are very different. If the problem persists, I will try some glue as I’ve read that really helps big flat prints. I may be printing this model a few more time, so I’d like it to look its best.
(BTW, the plate is clean:)
One thing I tried once when having a similar issue (PC, not PETG) was turn off the cooling for the first few layers. I had all fans/cooling off for the first 7 layers and my issue went away.
Alright, I put large brims on this model and the print still lifted some at the corners (shown upside down for clarity in photo). It’s acceptable, but perplexing. So, I’ll buy some glue and use it next time.
was wondering if you ever to get it to print right i am having the same problem with my X1c and H2D the H2D even worse. i even printed .20mm square cubes and placed it all over the place and it still lifts.
the only thing that is turned on is the exhaust fan on the h2d and its set at 45% and chamber temp will very on a hot day its 39c at night 36c bed temp is at 80c. on the x1c everything is off even the exhaust fan. i never have the lid open i’ll try to keep the temp around 40-42c.
