I thing the optimization for the Laser fill function is not very well organized and adds quite a bit of time that isn’t really needed.
I have a design with a pattern running around a frame, the pattern is only 15mm wide top, bottom and sides, the way it runs through it only in the x direction for the laser infill, this adds a significant amount of time, over an hour on a larger size print because it’s basically running back and for the entire width and and depth of the sheet. if it ran front to back for the 2 side patterns it would cut the time but about 60% or more.
Anyone know how to do this? if not is should be in one of the bambu Suite updates as it would be a huge time improvement.
Thanks for the consideration.
