I have some ridges started appearing on my P1s, I thought initially it was wet filament, but after drying, trying different filaments and machines I conclude:
I may be an issue with your K value as the greatest problem originates at the seem. If you move the seem to another section does the issue follow it? Is it only an issue on this part?
Ok then, I’ll calibrate K again. I would say it’s most visible on this part, I think because it lies on a smooth corner. I have a part that is almost the same in shapes, but joined, and I think because the seam was hidden at a sharp edge it’s basically invisible.
Ok, in the end I printed 4 more samples, and finally figured out it was the wall order. I was using outer/inner, switching to inner/outer gives a better surface finish. To me this is counter intuitive, but I don’t actually care as long as I know.
Does this make sense? I assume I don’t have another underlying issue if this is the fix.
