Hello all this is my first post so I don’t know what info to include or not include. I’ve been printing on the p1s for a while with this filament and I’ve recently had problems with some bad layers. Does anyone have any suggestions? It is dry and I’m using a gyroid infill with 2 walls at 10%. Any help is appreciated!
What material? If petg, slow down and use higher temp. If not, try this anyways, but for PLA max 245 degrees.
Check for snags on the filament roll
Using Rapid PLA from elegoo at 220 degrees. Ill give it a try.
Didn’t notice any snags in the filament but it’s possible thanks for the suggestion.
Thank you both for your help I think it was just an inconsistent spot in the filament I haven’t had it happen in a few days and it isn’t happening with other filaments either.
