Having trouble with layer shifting (or something similar) see attached pics. And it always seems to happen on all of my prints where the floor of the print ends. I have tried numerous things, including switching the wall generator to Arachne. But none of them seemed to work. this error is missing up, basically all of my prints, I am about to open a support ticket with Bambu lab
When such an issue occurs, you can try adjusting the order of the walls printed.
Using Inner Wall / Outer Wall / Inner Wall could help, but please note that it can affect the overhang quality depending on the model printed.
A fillet on the inside corner wall also seems to help mitigate this issues.
I believe that I did put a fillet in the inside corner wall but i could be wrong
This was the reply to my 1.7mm shift after 38 hours printing. This was the third time.
None of this was an issue.
table td { border-collapse: collapse; }
Dear Customer,
Thank you for contacting Bambu Lab support.
I am sorry you are experiencing problems, but rest assured we will provide support to solve them as soon as possible.
Based on the 3mf file you uploaded, it seems generally fine. I believe external factors may have caused the issue. I suggest following these steps to readjust:
- Tensioning Belt: Tensioning Belt
- Lubricating the guide rail system: Lubricating the guide rail system
- Check if the USB-C cable might have caused any lost steps during the printing process.
- Ensure there is no under extrusion in the nozzle, leading to insufficient filament flow and potential scraping of the model.
Kind regards,
Bambu Lab Support
I slowed all accelerations to 200mm/s and no faster than 50mm/s on prints and non print moves and it still shifted. This is a full spool on the table now. 1.7KG to finished part. 10x10x10"
Any updates? I’m having a similar issue but haven’t contacted bambu support yet
Update? I have been having the same issues, even after belt tensioning, and lubricating.
I sliced tall heavy parts into 3 plates and glue pieces together. I’ve printed 10 tall 7” dia 1mm thick tube with no issues.
