Layer shifting
Hi All,
I was printing an Aux fan saver: ( Printables) in PETG. (Extrudr XPETG MATT black).
Nozzle temp 245, bed temp 70 degree. 0.20mm Standard.
First layer 50mm/s, outer wall 200 mm/s, inner wall 300 mm/s.
Wall loops 5
When the print was done I did see a layer shifting. See picture.
What did I do wrong?
If you ever figure it out, let us all know. I printed a small forest of tall, skinny cribbage pegs (200% normal size) in standard mode and was so impressed that they printed! Then I noticed the layer shift. Eeeesh. Eyeballing it, I’d say it was at about the same layer as your pic. Standard PLA. They all went in the bin. A damned waste.
I have no idea what went wrong. I sliced it again with the same settings with bambu lab slicer. There was no layer shift visible in the software. I printed it again with the same settings, but now with 4 wall lines instead of 5. The print is successfully printed. Really strange.
I’m getting exactly the same problem. Massive layer shify for no reason early on
Try the following:
  1. Retension the belts:
    Belt tensioning procedure | Bambu Lab Wiki
  2. For the infill use Gyroid pattern
  3. It already looks like you are using a brim which is good
  4. The model looks top heavy. Is it possible to use support? If so, could you add it and then retry it?
Please try all 4 and your part should print. I had to do the above when I had a part that was top heavy like yours.
This looks like the belts skipped maybe? I would definitely check their tension before printing anything else.
Check if the layers shifted on a travel move or on an extrusion, in other words: is it completely cleanly split or is there a string somewhere attaching the two shifted layers?
What accelerations were you using? Was jerk control enabled or just the basic settings?
Just wanted to come and give everyone here some help if this is happening to them: check out my layer shift. It’s about 1mm in both x and y, but only one random spot. This has happened twice now and it’s being combined with plastic clogging in the poop chute. I believe the plastic has hooked the extruder/nozzle assembly head and caused it to get knocked out of place. It’s never done this before but now it’s getting clogged, I think it must be too hot during the filament changeover because it keeps clogging the poop chute and causing thick blobs.
I’m not sure if I changed the settings on this one, I may have made it hotter by accident. I also recently moved the machines into my garage, which we live in Florida and it’s summer. It went from 72 degrees F inside to 85-90 degrees F in the garage. Fixing the heat problem will almost 100% fix the chute clogging and thus any layer shift caused by it during changeover
Oh and fyi, blue Sunlu PLA+ is not as strong as black Sunlu PLA+…
