Layer Slider
Anyone else have the problem with the slider on the right hand side of the slicer?
The numbers on the layer slider are cut off and have been like this since I started using bambu studio back in December. It is the same after last the few updates also.
Running Windows 11 Pro
No
No problem here, also Win 11 Pro. Similar problems have been caused by customized display settings. Try a right-click on the desktop for Display settings, then change your scaling factor and/or text size.
Comparing the text/slider proportions of your picture and Neiljt’s, text size looks like it may be the issue.
These are my current display settings from a list of
here are mine, set at recommended. It does disappear at less than 300%, but then all is too small to read :slight_smile:
I use a 40 inch monitor (tv) and hdmi, i find it a lot better than the computer screen
can you try scaling at 250% ?
The “correct” balance of scale and text size will depend on your screen size, resolution, viewing distance, and vision.
Playing with my display settings, Studio cuts off the layer numbers if scaling is at 250%, but not at 200%. I think the spacing to the Slicing Result box narrows as the scale goes up and the eventually the box overlaps the numbers. The missing bits are not restored if you collapse the box or move the slider. Windows text size does not have any effect on these layer numbers.
With my 48 inch 4K (3840x2160) TV, sitting just past my outstretched fingertips, 110% scale with text size at 125% works well to show a large amount of information at an easily readable size. The Windows-recommended 350% scale assumes I am at a more typical TV viewing distance. Since I sit much closer, things do not need to be scaled so big. (100% is too small for my eyes)
Use your monitor’s “native” resolution for a sharp image, but experiment with your scale and text size to find a good combination that works for you and all your other programs. I use scale to adjust the display size of “things” (system tray icons, buttons, window borders), then adjust text size for easier reading.
This is a bug, there should not be a cut off no matter what my resolution is. No other applications do this.
Bambu Studio Bug Reporting Thread - Bambu Lab Software / Bambu Studio - Bambu Lab Community Forum
yeah I figured out how to fix it. here you go . Bambu Studio Display Bug for Layers - #2 by Daann_ii
