Layershift after Filament Runout
Do you experience layer shifts after Filament runout?
With all my P1P machines after the latest Update I see layershifts when the filament runs out and I resume the print the next day with fresh filament. I start my prints from the SD Card.
Looking forward to hear from your experiences, thank you.
On my P1P the last 2 filament runouts had no issues with layer shift after resume the print. My P1P is on the firmware 01.03.00.00, which solved the layer shift problem on load function from version 01.02.xx.xx.
Did you start the print from sd card or directly via Studio?
Normally from Bambu Studio, but sometimes also via Bambu Handy App, if I reprint a model. But I don’t think, that it has to do with printing from SD card. But you can test it. Are you using an AMS? If not simply cut the filament at the role while you print a test model via Studio or via SD card. With AMS cut the filament in AMS.
Have you checked, that the newest firmware (1.03.00.00) is really installed?
Very weird, i will keep testing. :-/
Is it time sensitive, as in if the filament runs out and you let it sit there for a while when you resume you get a layer shift whilst if you replace the filament immediately there is no layer shift?
