Led Strip connected to original light connection
Hello,
I have a question, because I am not an electrical technician.
I bought an LED strip on Aliexpress for my bambu p1s printer / I connected it to the connection of the original lighting. I hear different stories about whether it is possible or not. Can anyone tell me if this is harmful? I can’t find any specs on the Alie website. This is the link
https://pl.aliexpress.com/item/1005005952576069.html?gatewayAdapt=glo2pol
I did it, a piece of 30cm, which i connected at the original light of 5v; works fine until now.
When it is the 2.5 amp it is not smart
I keep reading that the connector under the tape on the P1S used for the factory installed light is only rated for 0.3A. So I suppose if you’re only drawing 0.3A you’re good. Anything more and you risk ruining the board.
Using that same led (juupine) on stock port with xtouch on usb A for 700+ hours, nothing to be worried about
