Did something break? Killed my nearly 30h print job
Yes, left hotend heater unit is cooked
Is this common
252525252525
The nozzle temperature is abnormal, the sensor may be open circuit. [0300-0200-0001-0007] I contacted support, but they haven’t responded to me for 2 days, I need help.
Had this happen to me and found the thermistor wire to the heater block was O/C.
Just received the replacement part so will fit tomorrow. It’s a pain to install though - had to do it before when the left heater was destroyed due to incorrect installation of the purge chute. Probably a bad install that time that caused the current failure
I ended up with the same issue (filament clogged up and taking it out stripped one of the wires); wondering if I can solder the wire back somehow?
