Lidar error msg
For approx the last three weeks I have been getting a constant error that the lidar is dirty and needs cleaned. I have probably done so ten times over the course of that period. Using IPA and water and everything non caustic I could think of. The printer has, surprisingly enough, never seen anything but PLA, PETG, or TPU so no real off gassing and from what I can tell this error has not led to any printing problems at all. What can be done if anything?
Thank you
Try a factory reset? Can’t say I’ve ever seen the error more than once.
It’s every print or every now and then?
I would make sure you are actually cleaning where the lidar lens is, it’s not super obvious and at an awkward angle. It’s easy to think you cleaned it and in fact missed.
From the wiki
I can’t 100% guarantee it’s been ever print but if not then 99%.
I have cleaned there But I will try it again before the next print. Thanks
I have had this problem twice on my X1C and both times it was the white rectangle on the righthand side of the build-plate. This is what the micro-lidar looks at first. If this is dirty it will give you that error. I clean it with a microfiber cloth. I hope this helps.
Cleaned both this and the sensor and I am still getting the error.
also have this Lidar dirty error every print, cleaning do not help me :frowning: …
and every time after plate read code.
Do you resolve this ?
XIC FW: 01.09.00.01
I have this error and all is cleaned properly.
They just answered me through a ticket to check what they had touched in the firmware.
I have gotten this on occasion as well. I found that using a cotton swab dipped in 99% IPA and cleaning the lens and sensors works for me. Then I dry it with a microfiber lens cloth and the issue goes away.
Are you using IPA when you clean?
I do use 99% IPA and have tried microfiber and Q tip to no effect. It still has the error msg but so far the prints are going fine just my concern is there will be something like forgetting to put a plate on that the LIDAR would normally detect and stop the machine that it will just continue to do.
Not sure. Your LIDAR might be going bad. If you’re still under warranty Bambu will probably send you another one. Sounds like you’re doing everything right but it’s still not working…
Unfortunately long since out of warranty. Unless it starts causing issues I’ll just roll with it most likely.
