Lidar to confirm Dimensional accuracy
Wish it was possible for Lidar to confirm dimensional accuracy and adjust exterior permitter and inner hole diameter dynamically to achieve better tolerances
Lidar detects distance, not dimensions. Besides, what would it have to compare it to? I have found the tolerances to be very good - you can make adjustments in the slicer if you need something more exacting.
just like how it measure’s the pressure advance and flow at the beginning. it would do something simila to measure XY steps per mm. calibration., with belt tensions changing over time and with user belt tension adjustment… doing an automated XY step calibration could be a great and easy way to achieve better dimensional accuracy
I totally agree!
It would be easy to print some samples ore lines and let the lidar do a simple scan.
compare the scanned information to “how it should be” adjust the parameter.
Maybee not inbetween a print but at minimum as a calibration process.
Bump to try and get more attention to this idea
