I’m having issues with lines in walls and sometimes inter layer cracks which align with changes in geometry nearby. See attached 3 photos, mentioned below. Finger for scale
- Printer model used - A1 Combo
- Slicer profiles used:
White: Standard profile 0.4mm nozzle 0.2 layer height.
Brown and blue: 0.2mm nozzle 0.1 layer height high quality and outer /inner walls order. - Filaments used.
Blue and Brown: Bambu Lab matte PLA
White: Copymaster3D PLA - Photos that clearly show the problem see attached.
- I checked and adjusted belt tension on all 3 axes to rule that out.
I tried calibrating both flow dynamics and flow rate for each filament.
I tried the slower high quality profile which reduces the accelerations and speeds
I tried outer/inner wall settings.
But still not solved
In the brown and blue I also had cracks as well as lines.
Any ideas on how to remove these lines.
Thanks.
