Lithophane issue
Hello
My first lithophane with my brand new P1S with Bambu Basic PLA… So not to nice :slightly_frowning_face:
Set 10 lines wall, 99%infill, slow speed and acceleration
  1. Where starts to print the layer there are “bubbles” looks like not enought material.
  2. Backside what should be need flat surface this is not.
  3. Somewhere little waves through more layers but same place
Can you help me please what can I do?
Thank you
have not tried one on my P1P yet but those are so thin that you could get by with 3 outer layers and no infill.
Those settings seem very different from what the lithophane printing guide suggests. Maybe start there, and see if that helps?
I’ve printed a couple dozen lithophanes now… and the only issue I’ve had was user error. The lithophanes all turned out great.
Hello
Please can you send me a link what you suggested?
I have no AMS and try 1 colour (white) litho
Thank you
Best regards
A simple search would turn this up for you. In this hobby, Google is your friend.
With that being said - here’s the link : CMYK Lithophane Printing Guide | Bambu Lab Wiki
It’s for color lithophanes, but the settings should be the same, just without the color changes.
I thinked you know a unique guide.
I know this guide but I have no AMS so CMYK is not relevant for me :frowning:
But what do you think, what setting seems very different?
Thank you
The guide is still totally relevant for you. Especially about the print configuration settings. They’re going to be the same whether it’s multi-color or single color.
There is a horizontal litho print where the object lies down.
Do you think it will be better quality instead of vertivally where the object stand?
However I see only 4 settings
  • Change the first layer height to 0.15mm;
  • Set the Top & Bottom Shell Layers to 3;
  • Modify infill to '100% Rectilinear;
  • off slow down for ovehang
Maybe I missed others?
Thank you for your answer
Best regards
Lithophanes give most detail when they are standing upright. With exception to the multi colored ones you should always print them upright and if on a bedslinger such as the A1 you should align it along the Y axis (front to back) to give it stability.
INFILL HAS ZERO PURPOSE IN LITHOPHANES as they are designed to look through, any infill can cause blemishes or voids and will ruin your image quality(even 100% infill is not 100%) Infill also takes the hotend off its natural wall path where again it can cause blemishes or voids etc…
AGAIN ZERO REASONING FOR INFILL ON LITHOPHANES
Set your walls to 999 and thats it, the hotend will now follow its natural path round and round until completion(no jumping to other parts of the print, just a nice smooth non stop flow)
Ideally you should give your litho a little bit of a curve to help it stand upright but you can also ad small supports to the side to help it stand.
I do tons of litho lamp shades and would never risk a 12-14 hour print by using infill
this was done at standard speed .20 layers
