Hey there Looking for a Bracket on the H2C 4 port Hub
it seems theres no one there , except for old versions
is there any bracket for this one ?
Are you looking for something like this?
New 4-in-1 Adapter II H2C H2D Halterung H2-Serie – Kostenloses 3D-Druckmodell – MakerWorld
If yes, there´s a second one, otherwise it´s not looking good at the moment
Seitliche New 4-in-1 Adapter II H2C H2D Halterung – Kostenloses 3D-Druckmodell – MakerWorld
Amazing spot on Thanks Man
Per my experience, I’ve never had a smooth flow of my filament when using a bracket for any splitter. If the splitter is left hanging it has a better chance of aligning itself from the PTFE in and then align itself at the PTFE exit. A bracket prevents that.
I came to the same conclusion after battling “feeding error”.
My idea is to feed the left extruder of H2C manually adhock from the container however it seems hard for the machine to pull the filament.
And I got some
I will try to put the box on top shelf and make the tube smaller
This threshold buffer saved it
Using the second link that was shared. Made sure the PTFE was cut so it sits as it should and have had no error from AMS & HT.
None of these works for me as I have all AMS on a right side of printer so wanted something to mount that splitter like was before with P1S/X1C feeding 4 tubes to the right (looking at the front of printer).
