I would like the shorter zigzag as in the orange box to look identical on the red square area. (Above)
I did a quick photo edit, here is what I want it to look like (below), is there a setting or a way to get the printer to print curves with shorter paths to help secure the path better.
I have tried re-orientating the object, but I get the same results. This is a PLA print and the image shown is the bottom layer that directly comes in contact with support filament (PETG - Yellow/Green Color). Even with 0.00 space between the layers there is no change the part with the longer stands of filament as in the red square area are not attached to one another as good as the orange boxed version. I have also tried concentric but still the longer strands don’t seem to connect together as good as the short path zigzags.
Hopefully this make sense?
