I have been using Cura for many years and have made the switch to Bambu printers and software and my only complaint is amount of supports that bambu add vs CURA, attached is an example of a Rim with supports in each, and the CURA supports are much less and not attached to the build plate, I have messed with the setting without much success, looking from some help.
Have you tried snug support, and uncheck attach to build plate only. You might also try checking critical supports only.
I thought I had seen your image before.
Have you considered tree support?
in some prints I do use trees but for rims like this supports never worked out very well.
I have not tried that, I will try that after work
