Hello everyone, I am trying to print a coaster with two colors, in the Prepare window it all looks ok, but when I slice it, it makes it with only one color. Please help !
Welcome to the forum.
Can you upload the .3mf file for this model?
coaster.3mf (1.7 MB)
It looks like the constiuent parts of all colors end at exactly the same z-height and that all parts are overlapping. So you are giving the slicer a choice. If you move the white Cylinder down a tiny fraction of a mm, the preview should look better and probably enforce proper color resolution after slicing. Alternatively, you can first subtract the black from the white cylinder, and then add the original black parts back into the cavities.
I haven’t had chance to review you 3mf, but, the following might help.
I have designed and uploaded a couple of hundred coasters, in two, three and more colours, a South African flag with 6 colours.
- Coaster diameters are often 100mm
- Thickness is often 2mm
- The above aren’t hard and fast, just most common.
- The artwork is usually 1mm thick
- A background (solid colour) is usually the remaining 1mm
- When you order the parts in BS, the top most is the background, the bottom is the topmost
- You are printing upside down (very common) to gain the texture, up and down are relative terms
- You have a significant number of parts for a two colour model, it is common to group colours into grouped stls, white one part, black another, sometimes the 1mm background a third
- The above grouping isn’t a requirement, just often makes life easier.
- As you are printing upside down, remember to change the X-a is as well as the Z-axis or it will be the wrong way round when printed, looking up from the bottom of the build-plate should look correct if the X-axis is correct
- The sliced view may well not look correct, but, it will look closer to the prepare view than the your preview shows, as mentioned by @EnoTheThracian it is likely you have the background overlapping the foreground elements.
Download any of my coasters to see how I assembled them.
https://makerworld.com/en/%40MalcTheOracle?keyword=Coaster
You will also find a few that print with more than 4 colours despite only requiring a single 4 colour AMS.
I was having a similar problem.
Preparing a coaster I choose the bottom part and add a color using the paint option, then the top part and paint with different color. Center both parts and assemble. But when I slice the assembled object bambu lab only assume one color.
So I started again and insted of using the menu to paint, I selected the filament (with the color that I wanted) to each object using the object menu on the left side. Then I centered and asseble both parts and when slicing it worked.
Hi I am also facing the same issue. I hope somebody can help me to resolve this.
I have tried the following but still am unable to resolve it:
- Turn off flush option
- Ensure to view the “filament” tab after slicing
- Changed the filament order
Seems like as a new user, I am unable to upload my 3mf. file
