Somebody point me in the right direction. Used up all the oil sent with the printer, which is the BEST choice to use as aftermarket lube.
None of the above…
White Lithium Grease (or anything similar) would be OK for the Z screws, but for metal rods you’ll want a lightweight machine oil.
I have a small bottle of Singer sewing machine oil I stole from my father maybe 40 years ago, that he probably purchased 20 years before that. Only need a little bit for things like small DC motor bearings and gearboxes and 3D printer rods. So the 3Oz bottle still has a decent amount of oil in it. ![]()
I bought a tube of this, which isn’t available currently.
I haven’t used it yet, I have this for the z screws.
For the rest, I have this on my Amazon list, I haven’t bought it yet.
My mother used a Singer sewing machine (industrial) at home for years as she was a self-employed soft furnisher. My childhood had that noise as its backing track!
I’m thinking of using this… think it is similar consistency to the oil that came with the printer.
Yea, they had a can of this at the store I was at, pretty sure I’m gonna go back and pick up a can. Preciate, Ya.
That’s not the same.
WD-40 has many products, you want “Multi-use”.
Just looked at the SDS on the Gel, made up from the same stuff. Petroleum Based Oils, LvP Aliphatic Hydrocarbons
Gel
Spray
They are same stuff one is Propane expelled the other is Carbon Dioxide expelled.
Side not, just ordered precision oil pen from amazon, have a can of the regular Water Displacement 40 in the garage. I’ll be using them, when it arrives. Caution taken, Thanks
My instructions recommended that as well. I cannot recall which grade of WD-40.
nah ill choose wd40 works best to me
ill choose wd40 for fast moving mecanisims
or just teflon lubricant here you have a link for it Fasi Spray Lubri. Teflon Weldtite Tf2 400 Ml aceites y lubricante bicicleta | Forum Sport
or grafite lube link for it LOCTITE® LB 8201 | Lubricante Loctite LB 8201, Aerosol de 400 ml | RS
Does Bambu Lab provided SDS documents for the supplied lubricants?
when you us wd40 do you just spray it on direct or do you spray the wd40 on a rag then wipe it on
i usually spray it on a piece of paper and wipe the thing u want to lube with the paper
I use these.
Oil: Super Lube 51004 Synthetic Oil with PTFE, High Viscosity
Grease: Super Lube-21030 Synthetic Multi-Purpose Grease
My research also led me to Super Lube 51004 Synthetic Oil with PFTE as similar and technically superior product to that supplied/sold by Bambu.
I used Singer gear lubricant grease on the vertical Z-axis worm screws. Unless you’re operating the machine in a very dusty environment the helical worm screws, nylon followers and slow speed of the Z-axis result in nearly permanent lubrication.
