Hi, I am using bambu studio on my macbook trackpad and cannot figure how to drag and select multiple items on my buildplate. Does anyone know how i can do this?
I don’t think it can be done. I can’t get it to work on WIN10 either, the plate just spins 'round and 'round. I use one of two work arounds. Right click and select all then hold Ctrl and deselect the one or two I didn’t want or in the process objects tree on the left, I hold Ctrl and pick the items I want. Obviously you will use different key combos but it should work.
yea, agree this is a bit of a pain - almost a year on and still looks to be an issue - be good if it could get sorted. But the multi-select in the Object view is a good idea - thanks @lasermike
You press command + click to select multiple objects
If you hold shift and then click and drag you can select multiple at once.
