MacOS BambuLab 1.6.2.4
Does anyone else suffer from huge instability issues of the above version?
MacOS and BambuLabs running on the latest version.
X1C connected via LAN only.
Problems:
BambuLab freezes regularly.
BambuLab always freezes after prolonged inactivity.
BambuLab regularly looses contact to printer, albeit strong Wifi signal.
Will only be cured when Force Quitting BL.
Then occasionally the printer does not want to be found, unless that is rebooted too.
Is this only me, or is this a more common issue?
The only issue I’ve seen with 1.6.2.4 on my MacBook is an occasional crash after I’ve resumed operation from Sleep. When I restart it asks to open whichever project I was working on. I haven’t seen any connectivity issues with my P1P.
Well, I have been playing around with it a bit.
Every time the machine comes out of Sleep/standby BL crashes (certain actions can still be made, but most don’t) and then becomes totally unresponsive.
The LAN connectivity issue seems to be a separate issue that I also encounter on a Windows machine.
It appears that the printer goes into some sort of standby and cannot be contacted anymore. (will see if there is a separate thread on here)
Also using 1.6.2.4 on a MacBookPro M1 - MacOS Ventura 13.5.
No problems…
Thanks for your response!
Still having the same issues. Once the MacBookPro (M2) restarts from sleeping, it stops connecting.
Running BambuStudio 1.6.2.4 on Mac Mini / Ventura 13.4 with no issues EXCEPT the inability to get it to see the printer when its set to Lan Only mode.
I have another problem with the program window, I missing a Button an some text by the AMS section on the right side!
MacBook Air M1 / Ventura 13.4
If you have multiple screens - Bambu Studio can go “missing” - showing icon only and no windows. (Not visible in desktop overview or by any other method like “show all windows”)
Resolve - unplug extra screens - studio screen re-appear. Connect other screens again and continue.
