Major Problem with new Add IP to view camera IOS/ANDROID
The new feature to add the IP address of the camera in Bambu handy has 2 major problems:
1 - The instructions say the location of the IP and access code are located on the sidebar. You can find the IP address if you go to wlan but there is no access code to be found.
2 - It looks like no one did any testing on an iPhone because there is no way to enter a period between the IP numbers.
Am I missing something? Here is one photo of the process on android with the ability to add periods and then the iPhone version:
So I have found that the Access Code is “00000000”, I’m not sure if that helps, but I hope it will help someone searching the same issue.
So I just went to my notes app on my iPhone and typed the IP Address in there, cut it and pasted in into the Bambu app. The code 000000 worked for my access code.
I know that’s not a total fix, but it worked for me.
where do you see the option for the IP? I have the latest version from the app store (1.0.9) and it gives me an error when I hit the play button to show the camera on the main screen saying Connect Failed … nothing else … has done this since I got it couple weeks ago.
The option to enter the ip and access code only shows up randomly so you have to keep trying
I can tell you what worked for me, what i did was this allowed camera permission to certain apps.
