Make accesscode static
Please make the access code (optional) static.
I’ve been using the same LAN access code for my X1C since May, when I last changed firmware and restored to factory settings.
Which printer are you using, and when does your access code change?
I have a P1S printer.
Everytime i turn off and on de the printer the access code is changed.
I use a BTT Panda , and when the access code was changed i cannot access the SD card in the printer until i change the code in the Panda .
Many thanks
I think we might be talking about two different codes. There is a six digit PIN code to bind the printer to Studio/Handy and a different eight character code for use with LAN-only mode.
The PIN code seems to be the most common trouble maker. A Google search for “p1s access code changes every time” found quite a few results. Try logging completely out of Studio and then logging in again with your Bambu username (email) and password instead of using the PIN. Or in Handy, remove the printer and then add it back to your account.
