I’ve been unable to upload a SVG file to Make my sign. I’m using Safari and wonder if that is a known issue or if other’s are having trouble uploading as well.
I was able to upload an example SVG file without issue using Safari on my Mac. ![]()
Do you have any other SVG files to try to see if it is specific to your file? Are you able to successfully upload it to an online viewer like https://www.svgviewer.dev/ ?
What error are you getting on the upload @Firefli?
I converted a png to svg with Pixelmator but the problem was that it was not vectorized. The only way I could do it was to use the key chain method.
