there seams to be a error in the new Make my vase app in makerlab
there is a problem with the strip effect which is making artifacts on the surface please see pics provided screenshots from Makerworld and Bambu slicer.
hope someone can help thanks.
Hi @brithawkes , could you provide the template file? You can download it by “download” → bottom left corner. You can paste the file here or you can send it to info@makerworld.com
I Have emailed the file hope it helps thanks
@brithawkes the file is well received and the issue is reproduced. We will investigate the cause of it. Thanks for your help.
I’m having an issue that was also posted 6 months ago by another user. Make my vase results in a vase with no bottom when sliced.
Tried reslicing for 40 minutes and changed every possible setting
Could you please share the template to us? You can export it in the download page so that we can investigate the issue.
