Maker's Supply needs more spring options
Currently most of the options are 0.6mm diameter or smaller. I would like to see 0.7mm and 0.8mm choices, such as
0.7x12x30
0.7x12x40
0.7x12x50
0.8x12x30
0.8x12x40
0.8x12x50
It may help to have some in the 13mm or larger spring roll diameter such as
0.8x13x30
0.8x13x40
I would like to see RC damper springs, and the main power springs for foam dart blasters.
I forgot one type of spring, the spiral torsion spring, the kind that is used in clocks. I had some ideas before for some wind-up toys/devices. The ones on Amazon are too big and too strong.
@BambuLab Anothing, the springs should be sorted by size, not by product ID as it is done now.
Since the size is specified in a standardized format, sorting can be done easily without having to create a separate variable in the dataset.
I would like to add some more choices.
  1. For 0.6, 0.7 and 0.8 mm compression springs, add some longer lengths, such as
0.6x12x80mm
0.6x12x100
0.6x12x120
0.7x12x80
0.7x12x100
0.7x12x120
0.8x12x80
0.8x12x100
0.8x12x120
  1. Some toy magazine springs. These can be used to make toy gun magazines (bullet clips). They will be too weak for making realy gun magazines so it should not be a safety problem.
