Please add some basic search operators to makerworld.com
For instance, I am currently trying to search for models created for the Amazon Echo 4th Gen, but there seems to be no way to exclude results for the Echo Dot 4th Gen.
Usually searching for echo 4th gen -dot would do the trick.
Also, please check out my other requests and let me know what you think…
Good, working searches seem to be like unicorns. Nobody has one. WHY?
What good is a search that shows anything with ‘cyber’ in it somewhere? Search for cyberbrick and see what you get.
Sadly, the site is still ‘beta’ and seems to improve slowly if at all.
Well, a certain linux ISO website i frequent has a search that lets you use both a text search and tags at the same time and even lets you specify which categories to search in
So its doable its just that most places want things to be quick and “functional” and they rarely look at adding things like exact searches despite pretty much every backend database supporting those exact things
Most of them tend to use " " to specify exact matches like google does, but even theirs can be a bit hit or miss
we can probably reverse engineer queries to find what database and indexing scheme they use too, but the cleanliness problem is user-content driven. The poor database is likely doing exactly as its told…
I just want their ‘relevance’ search to be better. The models returned often make absolutely zero sense. I have to switch to sorting by downloads or likes to get decent results.
The big problem with search is the initial classification. The poster is left to classify. Might as well be Radom. IE someone posting a figit toy, in the Tool/Gadget catogory. Then because there are so many already there more are added.
I agree it would be nice to have search options (any, all, not…). Have not tested but it looks like searches return any words used, anywhere in the post. and adding something like “dot” adds that to what is returned. Exactly opposite of the intent.
I wonder what the factors are? Why it didn’t work for Eliblue38
Maybe area, maybe some filter, maybe something happened to be down, country, … Maybe it is a feature not a bug. Can it be manipulated? I want a filter on searches “-dot”(from prior post).
Another complication is global language. My uses of words are different than other languages. Translation is not a simple mapping of words. I wish that problem was significant. It would mean the other problem of search was solved.
