I printed a file for my daughter in Bambu Handy that had a very coarse Fuzzy Skin which got me curious about the settings used. So I downloaded the file on my computer and opened it in studio.
Once open, it shows some settings different from what I normally use like the nozzle, filament/color, and layer height which is to be expected. I then sliced it and it shows a tree support and has the fuzzy skin, just like how it printed with Handy. However, when I go to the support tab it’s not enabled and fuzzy skin is off. If I enable supports it comes up as normal (auto) and not the tree support it sliced with. It doesn’t matter if I turn them on or off or change the type, when I slice it’s always the same end result. Which also means that I can’t see the fuzzy skin settings that I was looking for but I’m now just as curious about this behavior.
I guess I’m glad that the correct settings load that the uploader intended, but I’m a bit confused why it can’t be modified? Is this normal with MakerWorld downloaded files and some type of read only or locked file so the “optimized” settings aren’t disturbed? Or a glitch of some sort, possibly from the use of different versions of the software, etc, etc?
I’m away from my computer so I can’t look to see if there were multiple variations of the file that could be downloaded but I’m pretty sure I just clicked the download button. I’m curious now and it will be a day or 2 before I’m in front of a computer again so figured I would try asking here.
Thanks!
