Makerworld Error
Hello,
I keep getting this error that causes my upload to be classified under Failed on MakerWorld:
Not allowed to upload a 3mf file that contains custom printer/process types or filament types
Can you please help me understand what is causing it and what I should change to avoid it? Thank you!
Ok, I solved the issue.
I will leave the post here in case someone else encounters this problem.
I went back to Bambu Studio and under the Filament section, I selected all Generic PLA profiles, removing anything that I created. Then I saved again the .3mf file and the upload on MakerWorld worked.
RiverCross Diorama
As the word says, use the preset machine or filament parameters to upload, do not use modified ones.
Use a generic or bambu filament profile without changes and the same for the printer.
You can only modify the print settings it seems.
Hi Terry,
Thanks, I did it some minutes ago and I also updated my post.
It did not come to my mind to check on Bambu Studio, I thought there was something in the uploading phase that was not working.
All good now.
I just got this exact message. I guess big brother doesn’t like when you have settings on your printer that are better than the ones they provide.
