MakerWorld Server Instability — Frequent 502 Bad Gateway Errors (October 2026)
MakerWorld has been experiencing recurring issues for at least the past few days.
I’m frequently encountering 502 Bad Gateway (Host Error) pages and repeated “Please refresh the page and try again” notifications.
Sometimes the website works normally, but after navigating through several pages, it suddenly starts failing.
I’ve also confirmed that my network connection to Cloudflare is working normally.
Other users have reported similar issues here:
I was planning to publish a new model, but I’m now hesitant because I’m concerned that users may be unable to access or download it, potentially affecting its initial visibility and performance.
Is Bambu Lab aware of these recurring server problems? Are they affecting the entire platform or only certain regions?
Screenshots from October 24–25 are attached.
I’m having this issue with downloading a model from parametric model maker
I’ve been getting those popups, but it hasn’t been affecting the functionality of the website at all.
I am starting to think you are not
Same is happening to me, IDK what’s happening but if you refresh a few times it works.
Bambu Studio / MakerLab – Service Error beim Export von 3D-Modellen
Hallo zusammen!
Hat jemand von euch heute ebenfalls Probleme mit der Funktion „Image to 3D Model“ von Meshy in Bambu Studio?
Meine 3D-Modelle werden problemlos erstellt und angezeigt. Sobald ich sie aber exportieren oder auf die Druckplatte übertragen möchte, erscheint immer:
„Service Error – Sorry, a service error has occurred.“
Das passiert bei sämtlichen Modellen, nicht nur bei einem.
Ein Support-Ticket habe ich bereits eingereicht.
Hat jemand aktuell das gleiche Problem oder vielleicht schon eine Lösung gefunden?
Vielen Dank für eure Hilfe!
Viele Grüße
Carsten
3D-Wunschwerkstatt
Yes this very problem, tried many different things but I have been unable to export anything
have the same issue when I am at home wifi. But when I visit Makerworld at work it works fine. Probably problem with certain ip settings… idn. Looking for solution also.
Exactly the same issue here… seems this is not working for now
Same issue here. 502s galore.
Mam tak samo z tym błędem trzeba odświerzyć ale czasem zaskoczy
Same thing, on wired or wirless network, any device. “getting this on and off on makerlab ResponseError: status(502), body: {“type”:“https://developers.cloudflare.com/support/troubleshooting/http-status-codes/cloudflare-5xx-errors/error-502/",“title”:"Error 502: Bad gateway”,“status”:502,“detail”:“The origin web server returned an invalid or incomplete response to Cloudflare. This typically indicates the origin is overloaded or misconfigured.”,“instance”:“a50bd7e85d402fc2”,“error_code”:502,“error_name”:“origin_bad_gateway”,“error_category”:“origin”,“ray_id”:“a50bd7e85d402fc2”,“timestamp”:“2026-10-26T19:24:49Z”,“zone”:“makerworld.com”,“cloudflare_error”:true,“retryable”:true,“retry_after”:60,“owner_action_required”:true,“what_you_should_do”:“Wait and retry. Back off for at least 60 seconds. If the error persists, the website operator should check their origin server health and configuration.”,“footer”:“This error was generated by Cloudflare on behalf of the website owner.”}, req: {“url”:”/api/v1/creation-service/makerlab/credit/configs",“method”:“GET”,“headers”:{“X-BBL-Client-Type”:“web”,“X-BBL-Client-Version”:“00.00.00.01”,“X-BBL-App-Source”:“makerworld”,“X-BBL-Client-Name”:“MakerWorld”,“Content-Type”:“application/json”}}, cause: undefined, requestId: undefined"
I have the same problem 20/10/26 :frowning:
Also, all the parametric models seems to be failing when downloading the generated file
@MakerWorld @SupportAssistant : Are you aware of this? This has been going on for over a week and it seems not only it can discourage users from browsing MW but it also affects downloading of models for at least some users. No wonder a model I uploaded two days ago hardly got any downloads <<- joking :slight_smile:
I am getting this on other services aside from just MW.
Returned my bambu printer and have no issues whatsoever.
