I would like to know if it is possible to make a manual color change without using the ams lite, I have always done it with the “M600” on Marlin printers but I don’t know how to make a manual filament change with this printer. I only have it for two days.
Would it also be used to make keychains with several colors on the same layer?
Manual changes are done per layer. If you want to do multi colour inside the layer it’s best to get an AMS.
Oh thanks, I will try to buy it in a hurry!!
Hi,
I found this topic while struggeling with the same situation.
From my previous Elegoo printer and Orca slicer I am used to add a second filament in the filament section and right-click on a layer in the preview window and select “change filament”. This way the preview is rendered in the colors of the filaments.
However, this is not working, as my A1 doesn’t pause at all.
Should I try the “pause” option instead? Or is there a better way to do this?
Thanks
Thomas
