MIDI music for the X1 series
You can try this gcode I made, it’s very rough and unpolished but you can actually experience what you can get from the motors. Just extract the gcode from the zip file, put it on your USB stick or SD card and print (you will click print but don’t worry, it’s not an actual print, it will just play the music) :slight_smile:
http://philch.free.fr/Europe.zip
The link may not work by just clicking on it, so if not, copy the link in your browser and press enter to download (your browser might say it’s not safe to download but it is, it’s my work not a dubious download I copied)
It should work for both X1C and H2D
Just now tried twice again and it is not working on my X1C.
I would download your file, but for security reasons(here at work I can’t) -
But why not paste a small section of it in plain text?
So my gcode has several ticks in it.
example -
;Tick 11606, Time 116 sec
It has the semi colon at front which is merely a comment.
Here is a small section from the very start of the gcode:
;runescape-sea shanty 2 (2).mid
;music_long: 117.882294
M17
M400 S1
M1006 S1
M1006 L70 M70 N99
M1006 A58 B9 L69 C0 D9 E0 F9
M1006 A0 B26 C0 D26 E0 F26
M1006 A53 B9 L38 C0 D9 E0 F9
M1006 A0 B9 C0 D9 E0 F9
M1006 A51 B11 L69 C0 D11 E0 F11
M1006 A0 B7 C0 D7 E0 F7
M1006 A50 B35 L69 C0 D35 E0 F35
;Tick 106, Time 1 sec
M73 P0 R1
M1006 A50 B1 L69 C0 D18 E0 F18
M1006 A50 B11 L69 C0 D11 E0 F11
M1006 A50 B1 L69 C0 D6 E0 F6
M1006 A53 B11 L38 C0 D11 E0 F11
M1006 A0 B6 C0 D6 E0 F6
M1006 A55 B11 L69 C0 D12 E0 F12
M1006 A57 B10 L69 C0 D10 E0 F10
;Tick 204, Time 2 sec
M73 P1 R1
The whole gcode only comes out to about 31kb of space, and it does end with an M18.
I’m going to give it one last try and then give up for now.
Have you tried your gcode on X1C?
  • I don’t think it’ll work as it doesn’t seem to support this yet
Oops, sorry guys, It worked on H2D so I assumed it would be the same on X1C but just tried it on my P1S and it does nothing… So may be it does nothing on the X1C. Sorry
@philch No problems, they have the header and footer for the startup and end music in the machine gcode for the X1C. So you’d think it should work.
Btw - I tested it on my H2D and it works! Cheers!
Were you able to get it working on the P1S?
No, it does not work on my P1S
That stinks, I was hoping it would work since I have a P1S too.
Still nothing?
I was really excited to get something to play on my P1S but so far im out of luck :worried:
Hi y’all,
I think that I solved this for the P1S/X1C printers! Those were the only two that I have access to, so I can’t say much about others printers. I built a converter for midi files; you can see the web page here:
https://otherpuppy7-beep.github.io/Bambu_music/. I tested this very extensively, and it largely works well. There is one caveat, it can only take single track midi files (I haven’t figured out how to find the melody automatically yet). I hope y’all enjoy!
